Climbing gear for a newbie
TreeWalkerDJ
Hey all
Im looking to buy some new gear cause at the moment im using a prusik and the foot lock technique to climb which I find a bit slow.. Can anyone suggest any sort of climbing equipment that I could buy in order to make climbing easier?
Many thanks
TreeWalkerDJ
p.s im on a low budget :2in1:
Did you see anything on Saturday you liked the look of? You should've asked to try other people's set ups, thats what the climbs are all about.
If I were you I'd start off by adding a pulley to your hitch. It can be done with the prussik but would be less complicated if you did it with a different hitch eg. VT, distel etc.
Are you going to the arb show this weekend? If so, have a good look at other people's gear and ask as many questions as you can:thumbup:
Ditto what Dan said..."Walk before you run"...perfect the basics before you steam into mechanical aids. Watching you climb at the Reccy i noticed you have the enthusiasm and spent more time than anyone going up and down the tree which is a great start. Definately reduce your friction at your anchor point then sort out your friction manangement.But for now you,re doin just fine with a Rope and a prussick.
Cheers guys :) unfortunately Im unable to make it to the arb show this weekend :(. ive been looking on the web for cambium savers and seen a few i like so ill be getting them hopefully before the next climb. Im planning to head off to the local woods for some practice soon.
I did see a few things on saturday that i liked but as it was my first rec climb i was sorta blown away by it all :)
