Dieback On Cedar
alliaria
Hi All,
Looked at this Cedar today, extensive upper canopy dieback, the trees about 150 years old give or take a decade, not good at ageing trees, but I would expect it to be contemporary with other trees close by.
Anyway, spotted what I thought was Kretzschmaria at the base with associated raised dead bark.
I,ve never heard of this on Cedar, so I thought it may be some other Ascomycetes because it was unlike normal K.
Dug around for rhizomorphs, none to be seen, though I always suspect Armillaria in there somewhere.
Peeled off the dead bark and the decay/colour underneath resembles Phytophthora.
Anyone with any thoughts?
Cheers
Hi All,
Cheers
Armillaria my thoughts too also Sparassis crispa, did you notice a smell of turps when you were probing ?
Hi Jesse, there was no smell of turps.
What about Coniophora puteana ? It is a veteran so more likely to be a combination , Armillaria would be my first thoughts and ties in with the crown die back/ sparse foliage.
Along with ID, extent of spread is good to know. Perhaps remove more dead bark, so to find the margins of the infection? The tree's response at the margin, or lack of same, informs management, along with the name of the pathogen. Sounding with a mallet should get you to the margins quickly.
Turf culture to trunk seems the causal issue--a shovel might be handy. :elefant:
Hi, The tree is a Cedrus libani, I did sound with a hammer revealing a number of discrete areas with raised bark, but none associated with the blackened bark areas.
I haven,t removed enough bark to determine extent of occlusion, but I will today.
Decay spreads into buttress roots where I can see.
Will do some digging and take a lens today.
Cheers.
