Quicky question
predator
Spark plugs? They do fail, but not often. What does happen to all plugs is that the electrode gap widens with use, its eroded by its own sparks. A wide gap can cause a weaker spark and possible hot start issues. Plugs are cheap and a new one every now and then is a good move. I would never charge someone for a service and not fit a plug.
Needle bearing? These defo need grease, and as often as possible. Weekly is a good idea. Lack of grease does not just ruin the bearing, it wears the drum and the crank. A worn bearing results in a wobbly drum and on some saws, such as the 260 and 360, a wobbly drum can ruin the oil pump drive and even wear the pump casing. A costly repair could be saved by some very cheap grease.
