Probably 3 phase LV, but still LV. You can't have actual High Voltage (11kv) touching in a bundle fashion, even insulated they would cross phase to phase.
Actually I know of one piece of line which is 11kv in a 'bundled fashion', looks like normal ABC but more loosely wound, and have been told of one more in our area. It is unusual though.
Stuart.
  • Replies 21
Stuart.
I stand corrected. You can still check for sure. Follow the line. If it goes back to a transformer, its definitely LV. Either way if there's stuff closer than 4m, especially one rubbing the line, you'll need a shutdown anyway. If I saw it, chances are I'd probably do it live. Bundle is rarely switched out over here, but I couldn't make that call without actually seeing it.
