Thanks for all your Help
I will start with the coil and look at the flywheel
and also make sure the breather is not blocked on the fuel tank
Thanks again
Nick
Update
Flywheel is ok no movement
Breather had some dirt in it it also has a small grub screw in it i asume this is to stop fuel comeing out
removed coil and cleaned connections
got saw going used a tank of fuel worked fine
Cleaned it tonight it would not start took plug out only sparks some of the time
managed to find a new but non genuin coil on the internet for £24.00
at a place in Martley Nr Worcester beter than £74 for Stihl
I hope this fixes it
Thanks again for the help
I am not sure it is the coil
I have a feeling it is the HT lead but they dont look as if they come apart
for £24 it will save trying to bodge it up
The saw is about 10 - 12 years old
Usually the HT lead will unscrew from the coil so it can be replaced.
I do believe after a certain date stihl made ignition coils subject to a lifetime warrenty ??
true, but only to the original owner of the saw, and only if the stihl dealer properly registered you and the saws details with stihl at time of purchase...
HT Lead wont unscrew almost looks as if it is molded in
and I am the 3rd owner of the saw so that has done that option
I will get the new coil in the post by Friday will try that out and let you all know
Thanks for all the help
