  • Replies 55
...might just have to try for the bar and chain and cross cut bits then, is much experiance in this kind of event required or can a novice have a go?
Only pre-requisites are CS31 and CS38 for cutting and climbing respectively (insurance purposes!)
There are three categories in both cutting and climbing. Novice Intermediate and Open/Pro.
Your designation in a category depends on your honesty when asked about your experience!
The chainsaw bit involves the bar and chain change and a simulated fell. Basically we drill holes in 4m pine logs, cram pegs into them and stick the whole 'tree' in the ground with a forwarder. You then start your saw, fell it on a target, sned the pegs off and cut a disc of the end. Then a chap with a set of calipers measures all your cuts and awards points.
Oh and its all timed, so maybe that modded saw might come in handy...
  • 1 month later...
I might be home in the uk at the time of the comp and was wondering if i would be able to climb? none of my gear will be loler checked but its all pretty damn new-will i just have to show date of purchase? or could i just beg and borrow on the day? would i have to show my nptc card as ive got no idea where it is these days?
