dun dun dun.....the throne
arbmark
macrocarpa - its only taken 4 years!!!!
thanks to trollspiel for the help with the finishing.
sadly the picture quality is dire so you cant see the shimmering highly finished grain patterns.... (looked awesome in the sunshine today), but you can see my new boots in the background. every cloud and all that...
woah thanks guys
the process:
chainsaw! boring and slicing bits out the centre
bash off the bark with a blunted chisel to keep the trunks natural form
anglegrinder with 'arbortec' disc to rough out the shape
anglegrinder with 30grit disc to smooth out the gouges out left by previous.
random orbital sander with 60grit to iron sufaces flat, then 120grit, then 240 grit.....
wet down with water to fluff up grain
repeat with sander on 240grit
(water again if you can be bothered, then 240grit again)
then oil
allow to absorb, then wax.....
seat shaped using a thin piece of hardboard, trimmed with a jigsaw and repeated scribing to follow curves.
wall diameters - by feel im afraid - if you go through the wall on a flute or something, just make a feature out of it
carving out the middle is quite simply a bugger unless you have a nice hollow chunk of beech or a long bar! if the bar goes through then you can cut out triangles easy
probably took about 25hrs at a guess
:thumbup1:
