Schlieling /Premier.
woody paul
never seen that bit come off should be able to weld a bit in the as the flywheels are cut out of sheet steel unlike some which are cast, From what can remember think you can send it off to germany to have it repaired balanced and crack tested. you may be lucky to find a second hand one but as you know there built like tanks and last.
To be honest, I would yack it out and take to a local engineering company, get them to quote for a copy. Be a lot cheaper than a new from from anywhere and safer than a knacked old thing which might now have an undersized shaft! or be bent etc. Good Luck, it is only steel!
