Tractor v mog v Fastrac
stoxs
  • Replies 71
the MF is the same as the Fendt, you can mix power and speed to what ever you need, so you can do 40kph at 1500rpm or 40 kph at 2200 rpm or 5kph at 1500rpm or 5kph at 2200rpm all by mixing the power to speed knob. Then you can select the mode so by pushing the foot throttle it will just rev the engine to varing the speed with engine at set speed.
Takes time to set up but really good when you get the hang of it.
