the above tractor is a fendt xylon. the class make a tractor which is nearly similar but twice the size its called a xerion. quite a beast.xerion.jpg.3375add6f65d764a1c15b2cda009fd62.jpg
  • Replies 71
the xerion is ok, i found steering bit twitchy being 50k road speed and constant 4 wheel steering. having front and rear pto's and linkage and reverse drive capabilty make it a good vehicle for a wide range of tasks. might be a bit big for use in enclosed woodlands and it has a mass expanse of glass to break if something goes wrong
no load bay as the cab rotates and you need the vision for reverse drive capability.
my mate was driving a xerion on road and came up on traffic jam, so he rotated the cab and drove off in opposite direction at same speed, you should of seen the motorists faces
yeah they good machine but sooooooooooo many electronics, i subbed for a firm who change theirs every 18 months and it takes a year to iron out all the bugs,
during maize the other year i was playing connect 4 with warning lights on the computer screen in arm rest
is it a vario box then by Fendt or a different system?
The vario Fendt box is the dogs danglies drove a 7495MF with that box and it is so easy when you have your computer skills uptogeather
there are so many variations but basically the further you push it forward the faster you go, engine revs are seperate switch.
not sure about new mf boxes as havent driven any but i dont like the infinately variable transmissions of the 7930 deere i hired
