Does the splice on your rope fit through your rope guide?
Mine arrived today, and my spliced end won't fit through the cocoon. Which means I'll have to climb the tree, install the rg then pull the end of my line up and feed it all through. Obviously, this is not ideal. So I wondered if all ropes do this, or if your fancy 11mm ones work better.
Thank you, much love and goodnight.
  • Replies 60
You could always install it the wrong way around and melt a hole in the end of your rope to put your retrieval ball through? Or something along those lines...
However to answer your question, yes, the eye on my fancy ass skinny rope does fit through the pulley. Hope that helps.
Right... That helps. Looks like I'm gonna have try the other ropes at work tomorrow. If none of them work, I'll buy a new one. Cos I can't do with pulling 45m of rope through every time I install it. Thanks
I just made a rope guide with a pinto rig pulley and my tachyon rope go's through but the rubber stopper/ring that I use to close the rope splice just snags the pulley. works ok with a bit of force.
These is no way on this planet I'm getting my 13mm Marlowe rope through it. Thanks though
Is your pinto threaded through with the prusik line or is it connected by two separate tails?
looks like art had some sense then:blushing::blushing:
