Right are slings saying they are 2m does that mean its 1m tip to tip???
helps please..
Usually not.
If a sling is described as 120cm, then its made of 240cm of tape (ignoring the extra needed for joining the ends).
ie. the SLING is 120cm long, not the tape required to make it.
You could always enquire from the seller just what exactly is meant.
Depends on the type of sling - if it is an endless loop then yes a 2m loop = 1m sling.
If it is single part with spliced eye in each end then no 2m = 2m
Cheers
mac
