Saw isnt oiling right,
-when on tick over the oil bubbles out when the oil screw is turned up to max, but not enough considering the its turned up, when on full rev's hardly anything comes out,
I've run some stuff through to clean it, but to no avail.
Never had this issue before,
New pump needed?
Or can it be fixed?
If so How?
Cheers for any info
Pretty simple, the blockage will either be in the pickup in the tank, in the pump or in the feed in to the bar groove. Two T27 bolts hold the pump on and is easy to do once the pump is removed.
