I've put pallet forks, modified from an old pallet truck,on my compact and have set the linkage to lift as high as possible and reverse the pallet with the logs on. The only problem when using a pallet is you need to allow for an additional four inch lift, you can allow for this by making some basic ramps. I'm just about to order some folding pallet forks from up north which will save space and allow me to tow with the trailer attached. I'm quite lucky cause I've got ramps buit in under my trailer.
  • Replies 40
