  • Replies 20
How have you attached the pulley to the prussic? I cant quite make it out from the picture, & a stopper knot would be a good feature,looks neat.
pulley to rope?
Thats what I was thinking down the lines of.
If its a normal micro pulley,could you use a mailon to conect the pulley to the fishermans,as rope to pulley might not be desirable,those cheeks on the pulley are not designed for rope attachment,if that is how this is set up.:001_smile:
Ah ok Il have to re-think something else up.can I use a krab instead of a Mallion? What about tying the pully off like this using barrel knots.
Sure a crab would be ok,I like a maillon as if its being left set up,you can pinch the maillon up tight on the screwgate & make it semi-permanent.
Just my opinion here,must make one myself soon.:001_smile:
