I thought this might be of interest to any of you that are using the Uni.
The open L on the Uni has always been a problem in the fact that it does not capture the rope which makes it unreliable for slack tending. The tail can also find its way on top of the L and jam.
What the picture shows is the short side of the L drilled and tapped to accept a shoulder bolt with its head removed, sized to allow a 10mm opening. This space is large enough to squeeze the rope through so it is still mid-line attachable but small enough that it captures the rope during normal use.
I have been using this for awhile now and it greatly improves the usability of this tool.
Dave
Edited by D Mc
  • Replies 55
... Is the bolt fixed with a thread into the unicender?
Yes. Threaded and then secured with Loctite (thread glue).
Dave
Presumably you climb SRT. If so, why did you choose a Unicender and do you use a Rope Wrench above it?
I'm looking at SRT kit now and like the Uni design as it looks perfect for changing between DRT and SRT while in the tree. Although I suppose the same is true of a Lockjack and Hitch climber.
I'm really into the 'Rope Wrench Feedback' thread now.
Any thoughts?
Loving my unicender, yes I use it SRT on it's own because that's all you need! I have used it a couple of times ddrt when I've been climbing into crappy conifers and need to do change overs every 5 seconds! It self tends in ddrt but yo be honest it's much better SRT.
So do you not need a rw above the uni for srt?
Interesting. Is that because there is enough friction created by the 'bars' on the Uni against the rope to do the job alone?
I may be wrong but I think that would simplify the set up, less gear on the line.
Edited by Old Mill Tree Care
Realised my second question was irrelevant.
JUst curious but would it pass a loler if it has been modified like that?
Just realised your from USA so loler not needed
