Hitch Climber.... Am I just a big fairy...?
WorcsWuss
OK... first try on an HC today. Not blown away I have to admit...! :blushing:
Some known issues:
Used a VT from a length of 9mm boa with fisherman's either end rather than OP - will be ordering a length of 8mm OP e2e pretty soon I think.
Masses of friction at the top - I threw my cambium saver round the crotch but it's too short, so the rope was forced to run in an almost 'M' shape. It was only a couple of inches short but the rings weren't together. So at the very least I need a longer false crotch.
However, even placing considerable blame on those 2 issues, I can't help feeling I have missed a trick on this set up. I found it nigh on impossible to make any progress up the rope at all.
Using the 'all hands on rope' technique described in the HC guide I could move a little but not enough to get off the ground.
So, what the hell is wrong with me? :001_huh: Am I just a total ponce who needs to man up and pull it harder, or am I missing some dark art...? :confused1:
Yours
Confused and wallowing in self doubt.
Worcestershire
Edited by WorcsWuss
  • Replies 62
Having the rope forced into an "M" shape by the cambium saver being too short is what I reckon your problem was. That'll have a lot more friction than you would have had with the rope just going over the branch - that "M" shape will be working like a brake, the harder you pull the rope the harder the brake is being applied.
