Hi Mini.
1BIG Problem with telehandler to wide to get through gate way tractor went in with 2inchs. Plus gate way had 6 inch step had a job getting truck out when full had to block step and get square on so no lean to brick gate pillars.
HI paul lift one end of the log your loader tractor will lift 1500kgs on to low trailer all the best jon :thumbup:
Hi Mendiplogs. Did a job with crane driver told me 1 piece went 2ton tractor picked it but did not move it any were incase some thing broke crane drivers eyes pop out. You can move lift rams to lift more god no's what it will lift manual quotes 1750kgs ?.
Edited by woody paul
HI paul sorry mate but when we have arctic come into yard and they can not lift very large logs what they do is lift one end by lifting one end you do not lift all the weight so a 4 ton log a 2 ton loader will lift one end and then put the end of log on the low trailer then push with loader on the log on the low trailer but you will need 2 tractors as the trailer will move thanks jon :thumbup:
