Afternoon all, I've got an old 365 that has seen better days and hasnt been running great for abit. I was going to eBay it for spares BUT I've just remembered someone on here saying that the 365 can be re built (quite easily) as a 372xp, performance/power wise.
So I'm going to have a tinker with it on day's I'm quiet and see what happens.
Just need to know what parts I'll need??
Cheers
There is 365 closed port best, 365 open port.
372 will bolt right on. 372 comes in 50mm 51.4mm stock oem and 372 52mm aftermarket.
Over here they come with 2 different carbs and either will work. Walbro and Zama. Walbros has a little bigger venturi. I ran both on stock and woods ported and I didnt see any difference though.
So if I buy a 372 barrel and piston, it will just fit straight on and work?
As long as I buy a 372 carb aswell?
Cheers
Edited by Mozza
No need to modify the carb etc??
365 Max rpm 12500
372 Max rpm 13500
So even if it was the same carb and basic setting the H jet could be leaned.
My 365 Special was so rich when it came it would only reach 11800:thumbdown:
Carb dont matter. Run which ever one you have. Dont just go leaning that H side like posted above, big no no.
Tune to 4 stroke a tad WOT and clean up in the cut.
The coils if blue are rev limited and have the rpm stamped right on them. Black coil NOT rev-limited.
