new climbing rope ?????????????
burrell_
im after a bit of help i have 3 ropes in mind
1 Teufelberger Hi-Vee Rope
2 Samson ArborMaster Rope
3 Edelrid Timber Blue Rope
just wondered if anyone had any in put on any of these ropes im climbing on imora at the moment and looking to change it
cheers martin
  • Replies 36
cheers steve
maybe i should try a diffrent angle the problem i have with imora is when i sit on my friction knot (eg just to cut a limb off 1 min max) it really bits hard witch is ok but when trying to pull the slack through when working my way back up the tree its real stiff and really hard to pull the slack through
do u find this is or is it just me
i like the rope how light it is just that my problem
sounds like you need to play around with your hitch rather than your rope?
what hitch do you climb on? is the rope really dirty? i think if you swapped ropes youd be dissapointed as you'd probably get the same problem if you keep the same hitch configuration.
that said my tachyon is quicker to run through the hitch as it doesnt fuzz up the same as imori or poison ivy do. but i think that is of little consequence realy.
id say play around with your hitch before replacing the rope!
