Anyone using bluebeam pdf editor for producing tcps and tpps? Ive been using this for the last few projects as im a novice with cad. Bluebeam seems to do all i need and very easy to.use. Anyone else using this programme? Have you had any problems with this i need to be aware of?
"Never used it. Whats the mapping like for creating scales at A4? Or a nice picture would do. "
Scaling is easy as long as you have a known measurement to work from. You add overlays to an existing pdf map, but can also add pop ups with additional info like work specs for trees or CEZ info, whatever. There is a free 30 day trial version which I have been using but I think I will buy the software. Could email you a pretty picture if you want
A massive Thank you to Matt,
This program is unbelievable! So easy to use with the bonus of Pdf importing.
Basically I get the site plans sent through by the land surveyor. All done in CAD to A3 with tree locations plotted. Before i had to take measurements and create my own at A4. Here's the best bit! I can take the A3 map use the measuring tool to create a scale to the exact scale on the map. Then draw my RPA's exactly.
Try it, you Will Not be disappointed.
