Are Eucalyptus/Gum trees safe to climb?
lionpea
Perfectly safe as long as you use common sense and good climbing practice. Can be a bit bendy, and like ash, snap under load without much warning. Presumably you will be working with someone? Perhaps they will have experiance and be able to guide you on the job? You'll be fine...
Just Wondering if anyone can tell me if Eucalyptus/Gum trees are safe to climb as ive heard that they drop their branches?
Took down an 80ft eucalyptus last month on a blustery day with no probs using highest thickest anchors I could find,
even a dead 5inch diameter 30ft off-shoot I had to climb as it was hanging over a neighbours hut, safety first yes and a careful lookout for weak limbs etc. but their a go to climb unless their completely skeletal?
