Course requirements
Guss109
See you in aberdeenshire, wheres your course at?
Could go totally overboard like i did and pack in car a spare saw, spare chain for 2nd saw, extra combi can of fuel/oil, spark plug and start cord for 2nd saw plus files etc
guarenteed if you take it then you wont need it but sure as a cats a hairy beast if you dont you will need it
I'm just outside dyce. Are you from this neck of the woods to?
Yes and i agreed with you, but if you don't want to wear them for whatever reason you come up with you don't have to.
Sent from my aye phone using Tapatalk
I agree after you have done your training.
the lad was asking what equipment he would require for training and assessment.
AFAG 301
1 While ❏❏no PPE can provide 100% protection against cuts from chainsaws, the following should be used:
Safety helmet (complying with EN 397). ■■
Eye protection (mesh visor complying with EN 1731 or safety glasses to
■■EN 166).
Hearing protection (complying with EN 352). ■■
Gloves.* The type of glove will depend on a risk assessment of the task and ■■the machine. Consider the need for protection from cuts from the chainsaw, thorny material and cold/wet conditions. Where chainsaw gloves are required, these should comply with EN 381-7.
Leg protection* incorporating chain-clogging material (complying with
■■EN 381-5).
Cut from chainsaw, ie during sharping not use.
Cut from CS30 ASSESSMENT criteria
Appropriate work gloves
Risk assessment should determine whether gloves are necessary when sharpening taking into account the method and approach to the job, and the experience of the operator :001_tt2:
