Difficulty in retrieving pulley saver
charlie
Finding it difficult to retrieve pulley saver in any configuration any tips welcome!
Thanks in advance.
As said above, set it a little loose to allow room for the pulley to flip through the eye. Then when you are ready to retrieve don't just pull on the line but flip it forwards and backwards to send ripples up the line to help the pulley to flip through. This works well on shorter trees up to 20-25m.
Otherwise set a throwline higher than your anchorpoint and then you can easily fish it out. Hope this helps.
