  • Replies 34
Oversize trunks are heavy & additional lateral force to commence towards the tipping point is a good idea. Use a rope to pull the tree, or set wedges to lift the backside.
2
Oversize trunks are still smaller up high. Place the felling cut as far above the ground as possible to take advantage of this taper.
Hope this helps.
Not bad at all, maybe just leave your hinges a touch fatter as you have bored the middle. Is that a brown oak and what use will the tree have?
Cheers
The tree was a dead/rotten sweet chestnut,(had ganoderma (sp) )All going for firewood.
