Unicender Ddrt
atree
INSPECTION RECALL ON UNICENDERS !!!
8/22/11 – There is an inspection recall on the Unicender. All Rock Exotica Unicenders made before August 2011 are affected. This required inspection is important for the user’s safety and your Unicender should not be used until the inspection has been performed.
What Happened: An improperly riveted chain link came apart on one side under use. No fall occurred and the user was not injured. We have checked several other units from the same batch and there were no problems, but because your safety is paramount we have decided that all Unicenders must be inspected.
Click link for more information:
Rock Exotica Unicender - Recall
UniTether. set short and then extended long. when its in short mode its still a distance away but this can be over come by wrapping the tether over the uni to do remote adjustment.you can adjust from extended to short with full weight on the uni btw. not the best pics sorry
