Bracket living on cherry......so.......thought it may be ignarius although it doesnt have the fawn edge and the flesh seems too dark???
So toss up between applanatum and adspersum?? Over to you fungal freaks.:001_smile:
Which I second without hesitation, so what will be the next step ?
next step has already been taken.....twas a fell......
Sean,
Any pictures of the trunk base after it was felled ?
Hi Gerrit....
Although i felled the tree I left a 1.3m stump which is awaiting grinding. However after i cut the segment from the base with the bracket on i was able to push my hand into the stem.....conservative estimate would be around 30- 40% sound wood.......the tree itself had been through the wars and was none too pretty and more than a little ragged!:001_smile:
