  • Replies 38
I choke it off with a running bowline under my lanyard, works great, then just use your tail or a tagline to clip into the loop and pull it down after hitting the deck.
I see the pic shows it over my lanyard, but it is under it most of the time ;)
All good David, i dont have the grigri!!! :)
You should get one, they are very handy bits of kit:thumbup1:
I also use it sometimes for gaining access to the crown with srt using the yoyo method, and if you have a sudden need to get down (bad bowel problem:blushing:) then your already set up for it by simply taking off the hand ascender and pully:thumbup:
yeah ive played on the RADS sysstem a bit. i never really used it for access, always prefer the hand ascender, chest ascender set up. does speed up the ol changeover to descent though! definetly has a place in our industry i reckon, i dont think petzl agrees with the grigri being use this way though
Alpine butterfly would be easier to tie.
How would you use it to choke off against the stem? I'd try and avoid a karabiner due to cross loading issues and i dont fancy pulling my rope through the loop...
There is no cross loading issue.
Cross loading is loading across the minor axis.
I know what you are referring to though, and it doesn't bother me one bit in this application.
i dont use a crab simply because it slips off the choke sometimes when you take your weight off it, whereas the bowline can slip also but much less.
