Ifor Williams - tipping trailer battery size.
PhilBeech
I know I could probably find the answer online somewhere But...
The battery is shot on our tipping trailer, anyone know what size they are? standard leisure battery for instance?
Do they charge off the standard vehicle socket or be charged after a number of tips etc.
Cheers in advance...
there should be a number on the existing battery or a good motor factors will be able to ID it no prob to charge battery you will need the grey(caravan socket) socket fitted to the towing vehicle and ideallly a split charge system, this will charge the trailer battery while driving and when the engine not running it wont drain the vehicle battery when you tip
