  • Replies 38
It depends what you want to run on it, windows mobile is awful. If you want to run proper survey software then you better off with a rugged laptop.
I hate tough books with a passion, take an age to boot up and always going wrong.
How important is rugged anyway when the alternative is paper?
I use paper with a weather writer for complex surveys and the iPad with tables on for simpler sites. I have been known to put the iPad in the weather writer!
Because sometimes it is good for triangulating tree positions with known features on the plan directly into the program. Also when I am working away from home for several days I need to be able to use autoCAD in the evenings rather than wait till I return to the office to find I have missed something!
So what is the problem with the toughbooks? I would have thought by the Mark IV they should have ironed out any problems and that the boot up would be fairly quick. But I have no experience with them. What alternative would you recommend? I had been using a HP tablet but it is painfully slow and difficult to read in daylight!
Daylight reading issues, boot up times, poor battery life, crap data entry, software gremlins... if it was 400.00 I could probably live with it but I demand better when spending thousands.
When running a Picus etc I use an ordinary laptop and keep it in the van with just the cable running to the Picus. I'd look at a Mobilemapper with Digiterra or similar if you want to put tree features in accurately.
Even they have there problems though, dense tree cover being one of them.
I think the underlying problem is, we are a small industry so the products are always and compromise from another industry.
Perhaps have a look on eBay for a reconditioned one and see if it fits your needs.
Yes, without GLONASS its even worse... parkland environments are fine but as soon as you get into thicker tree cover its a PITA. You have to go out into the open to get a signal and then back under the canopy cover.
Still way better than anything else on the market though!
