Is cupressus worth milling?
alex_w
It is a fantastictimber for milling, well worth it. It has a very fine grain, which polishes to a high degree and takes oil etc very well. It is very vey stable, and can be used for many applications, both iside or out, as it is very rot resistant indeed. It doesnt have enough structural integrity for structural work in alot of cases though, as it is a 'short' grained timber- i.e. in small sections it can break diagonally across the grain. It makes fantastic furniture or decorative pieces such as window boards or sideboards etc, and often displays beautiful flame like figuring which can give a 3D ripple effect, somewhat like 'fiddleback' sycamore.
Makes good cladding for exterior uses too, and due to its stability can be cut into thin wide waney edged boards for this use.
Go for it!
It is, however, very poisonous, so wear masks when working it, esp when dry and you are sanding.
Everything said above is totally correct. We always have problems finding straight fairly knot free wood. Macrocarpa very often has included bark and big knots
which doesn't help the final product.
Macrocarpa timber is very naturally durable (far more durable than most softwood treated with modern preservatives. The shape of some of the uncut timber lengths sometimes make for great semi rustic tables,chairs etc.
Don't log it if it is any good!
