I used to get so wound up by having to fill electronic forms in, that I would give up.
Don't bother with the planning portal... it will just do your head in (eventually)
The planning portal is great once you figure it out, at least they have fixed the bit where you had to pretend to be posting further information.
I just did an application it took 15 mins from start to end, including drawing a scale map, with grid ref and everything. I may have infringed some copyrights but that is a different discussion.
