Full skip goes (in sequence down the chain) left cutter; missing cutter; right cutter; missing cutter etc.
Half skip goes left cutter; right cutter; missing cutter etc.
Alec
Just an update. I bought a loop of skip-chain from Rob D and fitted it to the 47in bar on the 076. I took it for a run today - a quick skim off and then straight through the centreline of an oak butt - 29in at the base, 24in at the top, 14ft long.
I don't have a lot to compare it with (066M doesn't count!), but it felt very very quick - chewed its way through and didn't bog down, although I'll have to play with the tensioning a bit. Couldn't really get an accurate time, as I had to stop and fiddle with a few things (wedges, top end of the tree, refuelling as the breather cap leaked etc) but I reckon just over 5mins, so say between 5 and 6sq.ft. cut per min.
The surface finish is poorer than with full complement, think of the finish on sawn softwood from a builder's merchant, but it's still flat and would plane up OK.
For what I wanted, which was speed, it seems to be a good fit to the saw.
Alec
Good stuff - sort of agrees with my thoughts on skip link in that it works better with the older, big torquey saws.
There still is prob a place for it with modern saws like the 880 for instance in very soft wood e.g redwood, or using a 30" bar where the torque isn't so vital.
