used to be a good saw
one of the better ones but 6 yrs ish ago they were replaced generally with a 372
ran some for yrs no major issues
more than I would pay
personally i would rather have the first £250 worth out of a new saw than the last £250
If that makes sense
If it is in good condition it will be worth it - check the sprocket is good, if you can pull the muffler and look at the piston through the exhaust port, if not, pull out the plug and shine a small torch down the plug hole with the piston out of the way so you know the bore is good. Otherwise seek a comp check.
These old saws were built like brick houses you need when you are bursting - very strong and will go on for years. I have picked up these older saws in beat up condition for £100 but sold them in good condition for £220 - 350.
As I say - in good knick, they will go on for years:thumbup:
I think you mean the green ones like in my avatar - they are 181SE and 288s and in generally very good little used condition.
The yanks like to tune them up and race them - very strong:thumbup:
