Pistons - fried like an egg!
spudulike
  • Replies 38
Any big bore kit has to be purchased complete - the original bores on saws built mid 70s onwards have plated bores with Chrome being on the older saws and Nikasil on the newer ones - only cast iron liners can be bored out.
Some of the US guys do big bore kits - Baileys are one of the companys but they charge $$$$$ for delivery to the UK!
Cost of fitting a P&C kit (customer supplied) - around £75 and will include a pressure check and tach tune to the carb.
i have a 460 too and it looks a bit like that, a bore out and bigger piston sounds cool, be very interested in a price for it including fitting. Ed
Unfortunately it's not that simple (or it's much simpler, depending on which way you look at it!). The pot is a magnesium alloy, lined with a thin Nicasil plating layer. Once the plating's gone, the pot is shot. Consequently you can't bore them out - big bore kit is a full kit.
Alec
