an error any one can make mind. would you say go bye one and use it straight off to some one? The systeum set up has flaws with no fail to saftey.
  • Replies 45
was a prussek designed for arb?
most of the gear and techniques we use are derived from other disciplines.....on one hand we are encouraged to be innovotive and on the other we're told otherwise!
Fair point, but it has shown flaws that make it less compatable with our DdRT systems. we still use the prussic the way it was designed to be used and cofiered but these belay devices we are not.
what exactly are the flaws alex?
Lockjack has be desiged for DdRT with a CE for that system, like all kit you need to learn how to use it but is a VT as safe as a lockjack?
"v.t's fail to grab and do need to be watched....yet no one tells us not to use them, why is that?"
because you've only yourself to blame if it goes wrong. :o
You pull on a sunt it can lock open even when realsed, Under load it is hard to move when it dose move is hard to regulate the speed with the device alown. If you get crap in the top twig leaf saw dust you will have problems you might not have bargined for. ask Petzl they will say not for that aplication.
i never had any of those problems when i used a shunt other than speed regulation, but then i had that problem with the lockjack too. admittedly i didnt put much time into the lockjack to get the hang of it good
