Hi Ian
Very good climb! Can you tell me what system you was using? Im climbing on a blakes and i really need to try someting different.
Cheers
A very finely/maybe a bit too far tuned VT in the video as i wanted it to self tend quickly. So in every day use it would have more wraps and cross overs. If your moving on fro a blakes and im generically speaking as you might try a VT and think awesome but id start at a distel or Howards hitch to start with as the movement is a bit different from the prussik/blakes technique.
The total setup is 2 oval crabs, hitchclimber rapide pulley and some armour pruss.
  • Replies 26
Would you get penalised for bringing the limb up? Or are the anchor points really too poor (low) for that? i.e. just run along the side/underside of the limb?
