  • Replies 25
I'll let you in to a secret ....Spark+Compression+Fuel=:thumbup:a running engine
In short, if you have spark (assuming your flywheel key isn't sheared) and your plug is wet??? Then if you have compression, your engine should start - there are a few things that can be exceptions to this rule like faulty fast idle carb stop and leaking needle jet but this basic engine maintenance!
Should have sent it to me - never had a non running saw I couldn't fix!
Magneto - a charging device of wire coils and magnets used to power lights on a moped etc - Coil - a device of wire on a laminated steel form used in conjunction with a magnetic flywheel to generate an HT spark
They are both completely different
Why do you think the spark is no good?
If the carb has been "full of gunk" I would suspect that it may be this depending on what "GUNK" is - in my day it was engine cleaner:-)
Is the plug getting fuel on ot it? is the engine poping at all.
If the plug is sparking then it is probably enough to start or at least fire the engine!
Have you inspected the front of the piston or done the "poor mans" compression check on it?
