Broadleaved trees lay down extra tension wood to strengthen branches.
Confers lay down extra compression wood to strengthen branches.
Am I correct with the above? Why do eucalyptus not follow suit, are they a type of confer? :)
  • Replies 24
rather than think "conifers" which sets your mind down a path, think gymnosperms
angiosperms (broadleafs) tension
Gymnosperms (primitive/conifers) compression
I dont know for certain yet, but i think this is another of those broad generalisations that traps a students mind into a path of confusions.
at the end of the day all trees have compression and tension, its more about how trees modify using the two, broadleafs can pull up a branch using tension, and conifers by pushing them up via compression.
But as with all these generalisations their are many shades of grey between the black and white examples within the lessons!
im not an expert in which trees do what, but I hope this helps a little.:blushing:
Tension / compression wood refer to anatomically unique tissue, generally produced as Hama notes by angiosperms and gynosperms respectively.
Of course stress is stress and the cambium may lay down additional wood where it is needed without being able to specialise it, giving the impression of compression wood in Angios (which I too have seen in E. gunnii) and tension wood in Gymnos (which I have seen on C. macrocarpa).
