is it really a good deal?
DrewB
just saw this on http://www.trademe.co.nz and was wondering if its really a good deal. ive got lots of wood available to mill (ie trees weve felled and left)and so was considering getting into it to make a bit of extra coin. i know nothing about and so am after some advice. and i dont know how to post the link so ive just copy and pasted sorry
105cc motor suit Fixed stand sawmill
No bids | No reserve | Closes: Thu, 7 Aug
Starting bid: $ Auto-bid
These are normally worth around $2000, but I can sell these to you at
the cost of a second hand one.. these are entirely suitable for a fixed
mill motor.
OSH has determined that they are not to be fitted with a bar and chain
and used as a normal chainsaw because they do not have a saftey bar and
brake. they do make a marvelous fixed mill motor...
LAST ONE UNTIL NEW SHIPMEBT (12 WEEKS AWAY) GETS HERE
**features**
* premium quality 2-cycle engine
* high-torque engine
* ignition system
type breaker controller magneto
* externally-adjustable, all position diaphragm carb with integral fuel
pump
* fully adjustable, automatic chain oiling pump plus manual pump.
* aluminum alloy front handle bar
* 3-shoe centrifugal clutch
* spur-type sprocket
* easy access air filter
* chrome-plated cylinder
* magnesium alloy case
* decompression valve
* fuel capacity 1.2 (2.5us)pt
* mix regular grade gasoline and branded 2- cycle engine oil
* *ix ratio
1:40 with stihl two cycle engine oil
1: 25 other branded cycle oils.
**manufacturers specifications**
* model cs105
* displacement: 105.7cm
* bore 58mm
* stroke 40mm
* dry weight, less attachment: 12kg
* 7 tooth 0.404" sprocket
* maximum engine speed with cutting attachment 8000rpm
operating range: 6,000-10,000rpm (10,000 rpm = no load etc)
net weight(powerhead only): 10.7kg/pc
**accessories**
* tool kit
weight
approx 11kg (without chain and bar).
comes with 36 inch bar and chain for milling operation. these are a
gift, and not part of the sale.
a truely excellent machine
yours comes still wrapped and boxed. I unloaded the one I am keeping to
have a play and then photograph it..... hell of a toy.
I beleive they are either genunine Sthil saws manfactured in South America or knock offs from China.
Sthil makes saws for the local market,German ones for europe,has a plant in the US and one or two in south America.
OSH woun't permit these saws to be used hand held in NZ.They lack a chainbreak.If I were you,I'd hold off buying one untill you have had a look at one in person.
Thats my $0.02
Thats my $0.02
cheers mike, going to have a look in person first.
