Howdy
The chain on my 346 is hardly oiling. I've cleaned everything you can see, bar and the slot the oil comes out of on the saw but it still isn't working correctly. I've had a gander in the oil tank and can see a little filter attached to a rubber pipe - how do I get it out to clean it, the pipe doesn't seem long enough to pop it out the filler hole? Is there anything else I can check too?
Cheers
Ger
