Evening all i've recently purchased a long handle hedge trimmer stihl one, it has a fs85 engine so its obvioursly had an engine change or a new cover on it.... sometimes its slow to pick up... and i've tried adjusting the one carb adjustment screw to no effect.... is there a factory setting for these?
i'm going to strip it and clean it all but wanted to set the carb so it picks up nice and crisp
cheers chris
FS85 is a brushcutter strimmer, I have serviced an FS80 - only has a single mixture adjuster for the "L" low speed mix - usually set to one turn out or thereabouts.
Set to this and ensure the air filter is clean, if it still sounds flat, it could be a blocked exhaust, carbon in the exhaust port, dirty carb or a poorly adjusted needle valve arm. The single screw carbs are a real pain - they always run rich and no way of adjustment - the manufacturers carry on thinking no one can adjust a carb but them!:thumbdown:
