Afternoon all
Was hoping for some pointers with regards marking of equipment for LOLER
Ropes, im assuming as simple as getting the heat shrink stuff and putting a number on a bit of paper and shrinking it into place?
Webbing based equipment, redirect slings, short petzl quickdraw, even Harness... how would I best mark these??
Metal hardware, karabiners, pulleys inc hitchclimber, grillon etc... How can I mark these? Im guessing stamping is obviously out, engraving?
all help gratefully received!
Jim
Yup, but I would use permanent marker on fabric (plaster) or “dymo” type label. Dymo do a printable heat shrink but it’s a tad expensive and I still have a lot of the old stuff to use up.
If they have a label write on it with a sharpie, otherwise directly on to the webbing
My choice is engraving with a dremmel or similar on a non load bearing area
Andy
Thanks Andy,
this might sound a bit stupid, but which part of a pulley and especially a karabiner would you regard as being 'non-load bearing'?
'biners im supposing you could mark the outer collar of the locking gate mechanism?
as to where on my pulley cheeks, im not sure where i would mark. I suppose take my cues from where the manufacturer has stamped/engraved their own serial number?
I use a few turns of yellow insulation tape on my rope then write on it with a black marker then put some heat shrink on it. For things like webbing I still use the yellow tape then just cover with sellotape, it does wear a bit but it dont cost much. I use a dremmel to mark all my biners and pulleys. I mark my biners on the bit that you turn( dont know the name for it) pulleys I mark on the side plates.
A lot of stuff already has a identifying number on it. I think most petzl stuff does, and my pulleys and lyon slings have been lolered without adding any markings just the numbers already on them.
Without looking, I dont realy know.
Idealy everything will already be marked by said manufacturer.
But anything else will be as above, all on a non load bearing part, or in the case of webbing - labels or again a non - load bearing part (ie not the bridge of a harness!)
Be careful with the pen, as chemicals in the pen could actualy contribute to the deteriation of the webbing.
Thanks John! so if there's a manufacturer's serial, I dont need to necessarily assign my own? I might do it anyway in order to seperate any duplicate kit in rigging and climbing kits in the future
either is fine.
to be safe, look at several identical items (Krabs are easy) the krabs will be identical except for the numbers assuming they are marked correctly.
But again, a decent loler insp will quite happily mark items for you as part of the service (labelling, engraving etc)
Edited by john dawson
