yes you can but for me on the landrover i can fit the air con pump with the brackets and pipe it up with switch and tank from matt savage or a lorry breakers and they put out enough air to run impact guns and blow tyres up fast etc ! :)
do you have a LAndrover then if so ill find the link/s to the on board air threads that are of use !
Yes standard LR aircon pump 200 or 300 tdi disco usually depends on the belt you need V or polly V serpentine
