  • Replies 24
The legs went off to a local oil hydraulics engineering firm and for the interest of anyone who may come across the same problem the diagnoses was..
Both of the rams cylinders had a bulge at the bottom. This was causing the seals to blow leaving the legs stuck out.
They took the two of the best spare legs and fitted new seals.
remember to check the pressures on this. ballooning can be caused by pressure intensification where the viscosity of cold oil goes sky high and causes oddball failures like this due to uncontrolled pressure . did this fail after a cold spell
Good advice. Thanks.
