they dont look like any rim sprocket i've ever seen, but carlton make reasonable kit... give it a go. i'm pretty sure there are stihl rim sprockets listed on the 200t ipl, i know they list a .325 sprocket (that ive never heard of anybody running)
Its should cut down on the vibration caused by the drive being worn and the chain running on different groves
but obviously thats never an issue because you'd replace a sprocket long before it had a notch worn into it...:sneaky2:
just checked, no rims on the parts list, but 3 different spur sizes
cheaped to replace rims than spur sprockets in the long run tho rob...
Oh I see this is a rim and sprocket set up rather than a spur sprocket...:blushing:
That said a normal spur sprocket on the 200t seems to last a hell of a long time before in needs replacing...
