Is there any reason why I can't use a Whoopie sling as a cambium saver
As per the title really, seems to me that a whoopie sling would make a decent cambium saver and/or anchor point by chocking it around a crotch or round a stem and running a crab for your rope to slide thorough, possibly even a mini pully on that crab. It is adjustable in length so more versatile.
I'm wanting to make an anchor point in a nastily pollarded willow where there is nothing substantial to anchor to other than one of the 3 main 'stubs' that have tons of regrowth coming out of.
Good idea or bad idea?
  • Replies 72
Aye but I can get Yale Whoopies for £25, never seen a Loopie for sale in me local arb supplier. I take it you just choke the Loopie like a webbing sling with a girth hitch?
cambium saver is only £30
What if you need to use woopie and a cambium saver at the same time.Then your nackard
Just spend the £30 save your self the agro
What situation could I find myself in where a whoopie with a crab through it couldn't perform the same task as a saver?
Your using the device for something its not intended to.
Cambium saver is made for this job in hand.
Its like using a pole pruner for sending up a truck on the ground.There's always something made to do the job in hand
