lockjack
arbormaster
pulleys new to me going to try that one. been running mine of tachyon, better than your more standard semi static. less bounce, still can't beat using static line. thats at its best. does exactly what you want it to when you want it to. doesn't dig to hard into the rope. got told off for doing that though, again!
used it all day today and I'm liking it, keep going to grab a bit higher up where the prussic used to be! did find it a bit close to the harness though. def need a pulley now.
50ft up and didn't get any slack feeding
depends on what diameter your using if it's 12-13mm generally doesn't tend aswell, or maybe your rope was resting on a load of limbs below you.
