unwell apple
mal
Why was the large pruning wound made? did this section die back, or was it pruned out for other reasons?
It appears there may be some canker, as well as the Saprobic and endophytic fungi, this is as a result of the massive amount od dysfunction caused and associated with this large wound and the resulting die back of a large portion of cambium. This may continue to progress or the tree may stabalise and adapt to the wounding and be left with a decayed region.
the rest of the tree and growth appears healthy, clear that all this is due to the wounding and localised to the area of connective tissues.
Dont do any more pruning other than removal of deadwood as the tre requires as much photosynthetic area as possible to allocate resources to deal with this issue.
and just keep an eye on it, see what happens.
by the looks of your photos this is Bramley grown on m106 or m111,
Planted between 12 and 15 years ago,
the m106 is a vigorous root stock and the m111 is a drought resistant stock.
in the fruit industry the bark problem is called Papery bark canker,
most common on trees planted in wet laying areas,
the characteristics of these root stocks are that they produce plenty of wood and wood bud if they are planted in to favorable conditions.( rather than fruit bud)
then they are pruned hard to reduce the size of the tree thus promoting more woody growth.
check the drainage around the tree first.
Nursery training! good stuff gollum:thumbup1:
