You need enough to split the size of logs you sell plus a little bit. Even though on most logs you dont need the full travel you will on some & it then becomes a pain to work the splitting head through the log by adding planks under the log if the ram cant do it. I think mine does about 18".
would be better for you to build with a longer stroke, my splitter has a 24" stroke, but most of the the time it's set at about 11" to do 9" logs. it's foot pedal operated (owner operator all you HSE bods) and i've set up a linkage to allow for indefinite adjustment.
ok cheers think ill find a bigger one. i dont sell them its just for my own use, i burn a lot of wood. a quick measure of my unsplit logs show there around 12" and the fire will only take that but think i wold be better off with a bigger one, can gurantee at some point ill wish i had if i dont!!
I missed out on that ram anyway. When you say a bore of 3" do you mean the piston diameter or the overall diameter? I was looking at ones with a50mm piston and overall 100mm?
I am currently (well have been very slowly for the last 6 months:blushing:) building a new log splitter. I am using a ram off a silage shear grab which has approx 14" of travel and a good size piston which is about 70mm diameter. My old splitter, which was rescued from a farm scrap pile, has about two foot of ram travel but as I only split my own logs I have never needed to use the full ammount. Here is a pic of the old splitter part way through restoration, it needed a new valve a bit of hydraulic hose fixing and a coat of bright yellow paint :thumbup1:
Since this picture I have made the block that pushes the logs taller and wider to split awkward shaped logs a little easier.
Sorry, meant to say 50mm diameter piston not 70mm. I have measured my old yellow splitter ram also and this is only a 38mm piston but there hasn't been much that it wouldn't split. Anyway here are few pictures of work so far. Just needs a valve and hydraulic hoses and I may add a bolt on log table and some bolt on legs so it will stand about waist height :001_smile:
